4.8 truck engine high mount AC
Old May 20, 2018 | 09:45 AM
neverdun's Avatar
Default 4.8 truck engine high mount AC
I want to use a high mount AC pass. side and no ps pump. Alt is in the stock location high on the drivers side
Old May 20, 2018 | 10:18 AM
That's nice. What about it?
Old May 20, 2018 | 11:27 AM
neverdun's Avatar
Does anyone make brackets to mount the a.c. high on pass side without ps pump. ? Alt and a.c. only 4.8 truck engine.
Old May 20, 2018 | 11:47 AM
Check with Holley/Hooker. They make bracket to mount the AC high on the passenger side, in all 3 spacings via mounting kits. It's a matter of using the correct belt. I believe they also have brackets for alternator only on the drivers side but not positive about that. If so, problem solved.
Old May 20, 2018 | 12:52 PM
vooduchikn's Avatar
https://www.holley.com/products/acce...y/parts/20-131
Not sure about your exact config but Dirty Dingo has a plethora of combinations.
Old May 23, 2018 | 09:01 PM
neverdun's Avatar
Thanks guys.
Old May 24, 2018 | 10:45 AM
-TheBandit-'s Avatar
There is also Kiwk Performance. Used to be popular around here.
