LS Swap Wiring Issues
The car will crank but there is no fuel, spark etc. UNLESS I remove the O2A fuse from the fuse panel (circled). When I pull that fuse the car will start. It runs and drives but it throws all of the trans solenoid codes, will not shift through the gears (seems to be only in 2nd or 3rd all the time), and does not charge. I thought maybe it was a ground issue and realised I was missing one of the grounds from the back of the DS cylinder head to the firewall. I added that ground but it didn't make a difference.
Also, on a side note, when I key-crank the car I can hear the solenoid click but it does not turn over most of the time (maybe 1/30 tries) but I can jumper-wire the solenoid to the battery and it fires right up.
Any ideas what it could be? This car has been 95% ready to go for like a year and I'd really like to wrap it up.
Here's a link to a thread I started last year about the trans codes;
https://ls1tech.com/forums/conversio...ans-codes.html
It sounds to me like you might have more than one thing going on here. Have you measured your voltage at the terminal of the starter? This thread has some good info on troubleshooting that issue. I'm not entirely sure what to suggest on the transmission issue, other than to trace back each wire, probably starting with those connected to the transmission...
None of this explains why the O2A circuit kills everything though.
that the trans wiring is correct, since it's untouched from the factory configuration. So - what do the fuel pump & ignition have in common??Also - just to rule out the simple/stupid stuff, perhaps get the body grounded, & confirm positive voltage values at the starter terminal & distribution block. Those won't be the primary causes of the issues you're seeing, but they could be contributing...
may even have something to do with neutral safety switch.
Have you unplugged all the connectors on trans and tried it?
will need to fool the neutral safety circuit
is the fuel pump relay engaged when you turn key on?
