Jeep YJ LS swap problem
Fuel pump and sending unit which I wanted to do along with the associated fuel lines since the LS upgrade.
Fuel filter "again".
Fuel regulator
crank sensor and cam sensor.
Checked fuel relays
MAF sensor
Finally I replaced the O2 sensor on bank 2 with the help of one of my friends help to diagnose it. I lost 2+ months of enjoying the Jeep with my wife and myself using the Jeep this summer. I tried to do it myself but in retrospect I should have asked for help earlier. It runs better now than what it was before, I believe.
The learning thing is look to the O2 sensors as a possible problem. My codes only showed 1 sensor as a heater problem but as it was the problem was a faulty O2 sensor and it caused the above problems or symptoms.
