5.3 s475 300zx
Engine:
aluminum 5.3L
BTR Stage 2 turbo cam and spring kit
melling pump
arp head bolts
new cam & rod bearings
gapped rings for boost.028
gen 4 rods & pistons
lapped valves
862 heads smothed casting marks out of intake/exhaust ports
smith brothers bronze trunion kit
Nick Williams 92mm t-body
LS2 intake
Motion catch can
-10 fittings welded to stock covers
TURBO:
S475 83mm T6 1.10
Holley Hooker cast turbo manifold kit (t56 cross pipe)
FUEL (for now):
Deka 80’s
holley rails
-6 lines
stock filter
aeromotive 340
The suspension is fully adjustable. Solid diff and rear subframe mounts. Not sure on what coil overs I’ll be going with yet. The fuel system will eventually be a return style, dual pump on a Hobbs. -10 lines to -8’s to each rail. I wish I researched fuel systems more before I got click happy and bought stuff. Lines and AN fittings add up so quick.
