LS swap Gen 2 Camaro Clip...AC Question
I am doing an LS Swap into my 56 Chevy Truck. I have a Gen 2 Camaro front clip and the engine and trans from my donor 2004 GTO. The GTO LS1 has a low AC compressor mount and the AC lines I have currently run into the upper control arm mount. I've been told there is a set of compressor lines that are low profile and they exit towards the front of the engine...somewhere out there? Any help would be appreciated so I don't have to cut my upper control arm mounts and create a whole new problem.
You could change to a sanden sd7 compresser . Use the dirty dingo bracket, or the Holley low mount.you could also look up coldhose.com. I called them and they were really helpful making custom hoses for my ls swapped 83 cutlass
See if this might help out, if not there are others https://www.ebay.com/i/311784525190?chn=ps
