9 years later... the LS2 runs.
Old Jul 14, 2018 | 01:38 PM
Camaroholic's Avatar
Default 9 years later... the LS2 runs.
On an engine stand. Ha.
Been a while since I've been around... I'm sorta back to playing with cars after getting distracted for a while. I've got to go back to distraction soon, but I wanted to spend a while playing with my car stuff again. In about 2010 I had to drop the car stuff.
Started building a little engine cart back at the beginning of June. Had a bunch of 2" tube out in the shop, some big casters I got for free, and some scrap bits here and there. So I stuck it all together and built a cart for my LS2. I probably spent as much time looking through boxes for parts as I did fabricating. My shop changed over the 9 years, and stuff got moved around. I found GTO parts in boxes I didn't think had GTO parts in them. That's how bad it was.
Anyhow, I decided to put the motor & wiring harness back to stock form and just get it running. Hopefully one of these days I'll get back to work on the 79Z and drop it in there. At least with this running engine stand, I can check out the oil pan when I replace it (I have an F-body pan), change the front accessory drive (going to buy Holley brackets), and, well, when I decide to get the APS system back up and running again (it's missing a couple of minor pieces).
This was a fun little side project. The cart will also be used when I drop the front crossmember/motor out of my 94Z. Need to do that some day also.
Old Jul 14, 2018 | 01:53 PM
SoFla01SSLookinstok's Avatar
That's really cool! The way you fabbed it all up. Ready to run. Good luck with it man!
Old Jul 14, 2018 | 02:11 PM
truckdoug's Avatar
haha that's badass. nice work!
Old Jul 14, 2018 | 05:24 PM
Thanks. Maybe this winter I'll put the APS twins on the motor and run it that way... on the stand. Heh. Need to fix a couple of bits first before the twin kit is ready to reinstall. August is about to start and I gotta get back to other stuff...
Old Jul 14, 2018 | 05:57 PM
truckdoug's Avatar
I know that feeling. I'm always working on other people's swaps. So I try and make 30 mins a day for my projects. I plan out what I wanna do a day ahead. Even if I can really only be out there for 15 mins, I'll clean stuff up, pull out the tools I'll need, get it on/off jack stands. Little stuff like that each day.
Old Jul 14, 2018 | 07:34 PM
99 Black Bird T/A's Avatar
Good to see you back on the board Camaroholic.
That's a sweet stand and set up for running the LS2. Look forward to seeing more updates etc.
It took 14 years to get my 91 RS LS swapped & restored. Sometimes life just interrupts projects at various stages.
Old Jul 14, 2018 | 08:11 PM
14 years, that sounds like me, ha ha. I've been having some fun with this though. Here's a couple of pictures... One today, and one when I was mocking things up... which intake do y'all prefer - this one with the 94 Z28 LT1 airbox:
Or this one, as I was mocking things up during the build process...
I really want to keep going, but other things are calling my name... Maybe later this fall / winter...
