Crate engine crank sensor
Old Jul 15, 2018 | 01:17 AM
Mrngwoodstewie's Avatar
Default Crate engine crank sensor
These connectors seem compatible and orientated to each other as far as pins and male female shape. But the connector on the engine seems to have been molded with a block to the clip.
Old Jul 15, 2018 | 01:29 AM
Im guessing I need this 😔
Old Jul 15, 2018 | 01:38 AM
Nvm. Sorry for all the questions guys. I think I just bypass this pigtail and go straight to the sensor.
Old Jul 15, 2018 | 06:44 AM
Michael Yount's Avatar
You got it - I had the same question when mating up my PSI harness to a new crate LS3. Remove the factory bracket/pigtail and go straight to sensor. And, as I recall (my memory is crap) - the crank sensor is above the starter in the back; I think this one is the cam position sensor?
Old Jul 15, 2018 | 09:37 AM
Yup an yup. At first I thought it was some kind of “new” “used” perforated break away tab lmao ...smh.
