LH6 conversion 71 Nova
Old Jul 19, 2018 | 08:05 AM
LS1DEUCE's Avatar
Default LH6 conversion 71 Nova
All right gang, need some advice. I scored a 2006 Trailblazer with LH6 and 4L60E for a swap. Besides the harness, DBW pedal and PCM, do I need any of the other electronics? My other car is carb’d with an MSD controller, so I’m kinda lost with this one. I want to make sure I get everything I need before hauling the donor to the boneyard. Thanks in advance for the assistance.
Old Jul 19, 2018 | 05:10 PM
-TheBandit-'s Avatar
Does that year have an external/separate TCM? If so you'd want to pick that up too. Some like to reuse or adapt the fuel/relay center. Grab the MAF and front O2 sensors.
Old Jul 20, 2018 | 04:41 PM
LS1DEUCE's Avatar
Default .
Thanks, Bandit! After some research it appears it does have separate TCM. Good call, thanks for the heads up!!
Old Jul 20, 2018 | 05:35 PM
showdog75's Avatar
I'd also get the gas tank for the fuel bucket and pump.
Old Jul 21, 2018 | 07:40 AM
LS1DEUCE's Avatar
Thanks, Showdog. I had thought about that, wasn’t sure whether it would be useful with the miles on it.
