need help,,starter wire LS1 TO A 2000 s10
Old Aug 3, 2018 | 11:42 PM
walkerman233's Avatar
Default need help,,starter wire LS1 TO A 2000 s10
just helped my buddy swap a LS1 motor in his 2000 S10 he is using a standalone wiring harness but I know I still have to get power from the key switch to start it,,,I need help on this,,,I took the purple wire coming from out of the under hood fuse box,,but cant get and power on it with the key turned to start,,,thanks for any help
Old Aug 3, 2018 | 11:50 PM
ss.slp.ls1's Avatar
Did you tie into the stock fuse block for ignition power to the stand alone harness? I would have made an effort to ensure that I didn't alter that circuit during the swap. It sounds like you may have scavenged an ignition feed somewhere for the stand alone harness.
Old Aug 4, 2018 | 01:10 AM
Dimeomboost's Avatar
I used the purple wire but I also used the big reddish pink wire hooked straight to the battery to power everything up also I messed up once and even tho I don't use stock shifter it wasn't in park and wouldn't start so make sure collum is in park pink wire battery purple wire to starter also double check all grounds are good
Old Aug 4, 2018 | 03:11 AM
jayyk31's Avatar
do you have the wiring diagrams for both your 2000 s10 and your specific LS engine and harness? You should be able to plug right into s10 underhood fuse box and be good to go.
Old Aug 4, 2018 | 09:38 PM
Are the relays still on the firewall near the wiper motor the stock harness still there or all stripped out if u don't get it I'll go take pics of mine and help u trouble shoot it
Old Aug 4, 2018 | 11:31 PM
the under hood fuse box is still there and the purple wire come out of the bottom of it is what I thought I would hook to,,but there is no power when you turn the key on it
Old Aug 5, 2018 | 12:16 AM
Im going to need help to find out what I need to cross or hook thgother to get the starter relay working,,all the s10 wireing harness are gone,,so im look for help to get the starter relay working so the purple wire will have +12 volt when you ture the key,,thanks for any info and your time
Old Aug 5, 2018 | 02:10 AM
LLLosingit's Avatar
Do you have a power wire going from the battery to the terminal on the fuse box? If you don't nothing will work.
Old Aug 5, 2018 | 01:39 PM
slogo's Avatar
Don't forget about your Neutral Safety Switch, not exactly sure what all has been removed, but that may play a part in your issue.
Old Aug 5, 2018 | 05:57 PM
yes sir
Old Aug 5, 2018 | 05:58 PM
I have power coming in to the relay but the relay will not kick,,,checked the relay and all the fuses
Old Aug 5, 2018 | 06:03 PM
im thinking its something to do with the Neutral Safety Switch but all that has been removed with the old harness,,,there is a new Neutral Safety Switch plug on the stand alone harness,,but I need the wire from the fuse box of the S10's starter relay to start with the key
