03 mustang GT lm7/T56 swap
My intentions with it now are different from before. Long story short I had a buddy helping me out and since this is my first swap it’s all new to me and so buddy isn’t helping me out anymore and left me with a mess which I’m clueless on lol. The gm Harness is already done , depinned. I was going to use the ford cluster and get that to work but wayyyy to much work so I’m probably going to Order an aftermarket gauge cluster to make things a little easier. We went off an 02 non afm pin out and my pcm is from an 05 tahoe I believe it what I pulled it out of. My buddy was gonna wire the gm Harness into a ford relay box and run ac , fuel pump and fans off that but it’s just a lot of work. I’m probably over complicating it mostly cuz I’m confused on the whole wiring thing and it’s overwhelming to look at a bunch of wires and where to go from the gm standalone harness.
To start, I'm not sure going off of an 02 to do an 05 harness is going to be exact. I thought the harnesses changed in 03 to the green and blue connectors and prior to that they were red and blue. There were definitely some differences like the way the o2's were wired and some drive by wire stuff that I can think of off the top of my head. I'm assuming by "depinned" you're just saying that you got rid of what was needed. I would get a pin-out of both and run through them to double check everything is good to go. Easier to do that now than chasing a gremlin once it's in the car. If you want to get it to just run I wouldn't worry about using the ford fuse box. I personally have 4 relays running the car. 2 for the fans (high and low), 1 for the fuel pump, 1 for a key-on accessory for the things the car needs hot on key on and start. That's it. Then I fed the ford fuse block power so I could have the regular functions on the car like power windows etc etc. There are a lot of diagrams on the internet. Let google be your friend. lt1swap has really good write ups and great harness diagrams. AND this just got a whole lot easier without the a/c! Let us know if you get stuck on something specific. Good luck.
yep wrong pcm haha. Gonna get the correct one with red/ blue connectors , and picking up a new relay box I’ll be putting together myself. But yes the gm Harness is “depinned” meaning as you said, all unused wires are pulled and whatever I’m using is labeled and all. So I also did go over the pinouts for the 99-02 harness and made sure everything was correct (lt1swap was a giant help! I’m using this site for a lot of my wiring needs) after I put together the relay box Based off lt1swap.com’s link too for the ob2/relay box , I’ll be running it through the firewall and setting things in place before I drop the motor in. Really appreciate your help! I won’t hesitate to ask anything that comes to mind. Things are starting to make sense to me now haha
Alright sorry guys I've been ghost. Been working and putting money together. I got the correct pcm so that's one less thing to worry about for now and I'm currently on my way to pick up my k member from UPR!
Block is soon to be sent out for a touch hone and nice cleaning so she's brand new, ordering my rods and pistons in a couple of weeks from TSP. Thinking about the transmission ordeal now. I'm going to stick with my tr3650 5-speed that came out of my mustang since the motor is gonna be NA with a cam for now. Any advice on what's needed? New bell housing AND adapter plate or just bell housing, vise versa. I have accessibility for any fabrication needed as well, also should I go with the hydraulic conversion or stick with the cable clutch? Once the motor goes on boost a year or so from now I'll be going powerglide. Thanks!!
Since the 3650 had an integrated bellhousing I’m imagining like the cd009 it would have to be cut off and then an adapter added. The clutch is a pull style while gm is a push style so it would have to be completely altered. 10 spline input, And let’s add that a stock 4.6 mustang will destroy a 3650 or a t45, so this is a less than ideal trans for the money, even if you already have one. By the time you add up everything to adapt it your easily at the cost of a used t56. Then you’ve got to adapt the oss to the stock vss of the gm pcm. What lengths are you going to just to retain the Ford trans? If auto is the end result then just grab a $400 4l80e and be done with it. I was in this exact situation and after not wanting to spend the 1500-2k for a t56 I got a 4l80e and I couldn’t be happier for drivability. Car drives like stock, shifts great and it’s just a blast. I say sell the 3650 for whatever you can and the new gm trans will all but be free. Or find a MUCH cheaper alternative but I don’t think the ford trans is the answer.
Ahh thanks for the input guys! I know that it really would be easier to either cough up the cash for a used t56 to make everything easier or just go with a 4l60/80e. It's going to be auto once it goes on boost, I'm just being stubborn because I miss having a stick shift v8, nothing beats the feeling of slamming gears lol. Like I said it's gonna be NA for about a year or so til I'm ready to go turbo. I've got some thinking to do
#32
Honestly just waiting to see what transmission pops up first for the best deal lol. Fingers crossed for a t56! Idk who thought to let a girl build a car when she can't even make up her mind on what she wants for dinner lmao. Anyway, the motor is almost done! Pics will be posted in the next couple of weeks hopefully
#33
Hey who had to LET you??? Seems you're doing just fine. Here's hoping a T56 falls into your lap!
#35
A lot of us are in the same boat, money is slow to come in, not much time, the parts we want are high, we keep up grading over the budget plan. I just bought a Dorman LS2 intake, didn't want to use the ls1 intake. And lm over a year on my project
Stampede
Stampede
#36
Being that my motor already had stock rods and pistons in them, I'm going to have the bore measured after the touch hone but trying to decide how over I should go. I found these rods and pistons but as for stroke / piston length, I'm unsure if this combo will reach deck clearance. Maybe a little over, no? I posted the links, let me know what you guys think! Also yes I know they're very expensive and I could go a cheaper route, these are just sitting on the back burner and using them as for reference until I get everything measured to help me figure out what stroke and bore to go with then decide how expensive I want to go on rods and pistons lol.
https://www.texas-speed.com/p-4344-t...ting-rods.aspx
https://www.cnc-motorsports.com/1159...-800-bore.html
#37
See I was gonna do that but I'd rather take my time with it and build it right so when I wanna go turbo I can just throw the kit on worry free, or at least with more confidence lol instead of having to pull the motor , put in the new rods and pistons, rebalance it, just more down time on the car when I can spend the extra money to future proof it. It's hard to stay patient but the car has been down this long so why not take the time to build it right and for boost. I want to enjoy the car and not be scared that my junk 5.3 pistons may not get the job done, next thing I need is a valve hitting a piston or something haha. I already have another project going on too with my Lexus LS400 along with my buddy that's putting a 6.0 into his 1986 Mercedes 560SEL
#38
#39
Oh yeah definitely I totally agree with you but my luck I'd throw in a stock 5.3 and blow it on start up haha but I am definitely gonna get another motor to have on the side Incase anything. I really appreciate your and everyone's advice cuz it's good to hear other paths to take with doing the swap patient or not haha
#40
Update 2020
Trying to get power to the fuel pump. Only seems to prime the fuel pump through the ccrm, can’t get the fuel pump to work via GM side. Everything else is put together. Gotta figure out how to make the steering shaft fit and hook up the slave master cylinder
