Fuel Pump
Old Aug 27, 2018 | 07:17 PM
cookseyb's Avatar
Default Fuel Pump
I am putting a LM7 bored to 5.7 in my 94 GMC pickup. If I install a inline fuel filter do I need to remove the old in tank pump?
Old Aug 27, 2018 | 07:39 PM
You still need a pump. If you remove the in tank pump, what's gonna push the gas??
Old Aug 27, 2018 | 07:45 PM
Kawabuggy's Avatar
I think (but could be mistaken) that he meant to say an "in-line fuel pump". So, if he is installing an EXTERNAL, in-line, fuel pump YES you would need to remove the in-tank fuel pump. Your EXTERNAL pump will not be able to pull fuel through the factory fuel pump in the tank. And YES, you would still need to install an in-line fuel FILTER.... after your in-line fuel pump.
Old Aug 27, 2018 | 07:58 PM
1964SS's Avatar
Why not just replace the original in tank pump? it's already a fuel injection tank you just need a high pressure pump.
Old Aug 27, 2018 | 08:31 PM
^^^^^^THIS^^^^^^^^
Because external pumps can be NOYZEEEEE!!
Old Aug 27, 2018 | 09:20 PM
cookseyb's Avatar
Just didn't want to have to drop the tank, at my age it is areal PITA. any way Thanks for the replies and solutions. I'll drop it tomorrow..
Old Aug 28, 2018 | 08:45 AM
1964SS's Avatar
On some pickups it's actually easier to undo the bed bolts and tilt the bed up high enough to get the assembly out the top. I recently did this on a 2002 and was done in 2 hours.
