A-Body Fuel Filter Location
Old Sep 14, 2018 | 07:33 AM
Mikes64's Avatar
Default A-Body Fuel Filter Location
Just as the title says, any one have some input on where would be a good location for a fuel filter? This is for a 6.0 in my 64 Chevelle, might mention I have boxed the frame and using nylon fuel lines/ pressure and return. I'm trying to run this as close to stock as possible (no corvette regulator/filter)
Old Sep 14, 2018 | 10:34 AM
Primary or secondary? The primary (pre-pump) would be somewhere between tank and pump (in-tank pump filters also in-tank, obviously.. lol). Secondary can be anywhere between pump and fuel rail, so a convenient spot would be where the fuel line connects to the rail.
Old Sep 15, 2018 | 10:18 AM
garys 68's Avatar
Mines a 72, but I mounted it forward and above the tank. Post 103.
https://ls1tech.com/forums/conversio...2-build-6.html
Old Sep 17, 2018 | 05:51 AM
Mikes64's Avatar
Thanks guys
Old Sep 17, 2018 | 07:46 PM
1964SS's Avatar
Hey Mike I tried to respond to your pm, but you must be setup to not receive private messages.
Old Sep 17, 2018 | 08:54 PM
Mikes64's Avatar
I’ll try and fix that and send another
