Gen 4 wrong Cam sensor connecter
Old Sep 30, 2018 | 03:42 PM
Christopherson's Avatar
Default Gen 4 wrong Cam sensor connecter
Hi Everyone,
I ordered a swap harness for a 2011 6.0L w/ 6l90e. I mistakenly ordered one dor a non VVT engine. I have the old harness still. I assume I could just look at the pin out locations on the old harness and insert them into the new harness?
Is there any problem with this approach?
Thanks!
Old Sep 30, 2018 | 05:36 PM
So I depinned the 5 wire cam sensor connector from my old harness, and started spinning the PSI harness then noticed all 5 pinnout locations on the PSI harness are connected to something. I assume the current cam connector account for 3 of them, but not sure about the other 2. Any insight?
Old Sep 30, 2018 | 08:42 PM
brandon6.0's Avatar
It should be a 5 wire connector originally if it was a vvt engine. 3 wires go to the cam sensor, other 2 are for vvt. If u are deleting vvt thin your harness should be a 3 wire cam sensor connector only. Plug it directly into the cam sensor. Take the original metal bracket/short front harness off completely.
If u are deleting vvt and ordered a vvt harness thin just reuse the 5 pin short harness/bracket and leave vvt unplugged. Works either way.
Old Sep 30, 2018 | 08:45 PM
brandon6.0's Avatar
Or if u ordered a non vvt harness and want to keep vvt u will need to add the 2 wires back. Just go directly from the front vvt pigtail to the ecu. Its just 2 wires. U can look up the correct pins on lt1swap.com
