gen4 swap questions
Old Oct 3, 2018 | 11:39 AM
greasemonkey245's Avatar
Default gen4 swap questions
hello everyone, im sure im going to get told to read this link and read that or already posted stuff.... iv read for days and honestly im exhausted from it, so all help is appreciated. project is a 57 3100 with a 09 dbc 6.0 swap, vvt delete cam gear and cover with sensor. I had it all wired up to a 0411 pcm and hp tuned to delete vats and so on. ran into a no rpm signal and then lead me to find out that the engine has a 58 tooth reluctor and 4x cam where as my pcm is set for 24x and im assuming 1x cam. iv seen the Lingenfelter box and read its mostly bs... and also how hp was suppost to add more to there software to alter this and I haven't seen it.... basicly im left with change the motor or tear it down. or... get the 09 haness and pcm and do it that way. also has a 4l80 trans behind it. any hep is great, sry if this very same thing is posted but everything I read hasn't given me a more direct answer... thank you
Old Oct 3, 2018 | 11:51 AM
Old Oct 4, 2018 | 09:46 PM
Project GatTagO's Avatar
I would sell the harness and ECU that you already have and then contact one of the harness vendors. They can set you up with a Gen 4 ECU and a T42 trans controller. You will have to go do DBW, since none of the Gen IV ECUs have IAC drivers.
Andrew
Old Oct 4, 2018 | 10:25 PM
brandon6.0's Avatar
^^^ Correct!
Old Oct 4, 2018 | 10:49 PM
Dimeomboost's Avatar
I took 08 ly6 vvt delete and went 1x gear etc. Just like u and use a 411 pcm with lingenfelter box and it works fine not sure what the problem is
I have the e38 harness it came with as well as trans controller throttle body and tac pedal etc if u need one I use autometer gauges for speedo etc with th400
Old Oct 5, 2018 | 05:20 PM
it lives! tried the Lingenfelter box after reading more into it and saw the updates since the 2008 post that I had read lol.... but it did the job and its running strong
Old Oct 5, 2018 | 05:24 PM
had a few issues with spark even after, then I had found I was some how dropping voltage to the coils. even thow they were in the existing power source from the original fuse block? idk understand but moved them and got my spark back. first ls swap so it was a big learning curve for me.. but now its time to button it up and get the rest of the truck done. thank you again everyone for all your ideas and in put.
