JC72NOVA 4.8LS swap
Decent write-up about those manifolds below. They seem taller than the stock truck intake.
https://ls1tech.com/forums/generatio...-intake-2.html
Cleaned the pistons, new rings, swapped out the rod bearings even though they looked pretty fresh.
BTR cam was reused
Decided to replace the plastic oil barbell with the billet one while redoing the rear seals
The Dorman knockoff intake and valve covers were painted with a textured black paint
All back together and running!
There are things to tweak and finish up, a small cooler line leak, the shifter needs adjusted etc, but its back together and running again!
I was able to complete this swap by using PCMHammer and TunerPro to edit a PCM bin file from a 2004 SSR 5.3. I had some help from a fellow LS enthusiast with where to edit the file with TunerPro, and was able to upload the changed file to the car and get it running. I am forever grateful to @PeteS160 @NSFW and @B52bombardier1 for taking the time to walk me through making some changes over several emails.
I'm a moron and never knew this was your build thread. That is a gorgeous Nova. My first car was a same body style 70 Nova with a 307 smog motor. It had a leaky front window with a rusty passenger floor, gym sock smelly carpet - a real chick magnet it was. =:-( I could'a married Christy Brinkly if not for those smelly carpets!!
A set of Cragar Hot Pipe headers and a 600 Holley kinda' sorta' woke it up a little but it was still a low compression smog motor.
Definitely dialed in here to watch now!!
Rick
