Power steering return line issue
Old Oct 14, 2018 | 08:45 PM
Mikes64's Avatar
Default Power steering return line issue
Im doing a 6.0L swap in my 64 Chevelle. Donor vehicle had hydro boost braking which had the two return lines. The lower line is hitting the steering box, which is keeping it from being mounted. Can one line or the other be capped or can the lower one be bent for clearance? The steering box is a JGC swap as well.
Old Oct 14, 2018 | 08:48 PM
ls1nova71's Avatar
You can cap the upper one, you need to use the lower one for power steering only. It can carefully be bent out of the way of whatever it is hitting.
Old Oct 15, 2018 | 05:45 AM
Mikes64's Avatar
Thanks for the reply, I thought that could be done but had to check.
