Quick connect to AN for TR6060 hydraulic line???
Old Oct 23, 2018 | 07:37 PM
StolenFox's Avatar
Default Quick connect to AN for TR6060 hydraulic line???
Is anyone here aware if there is an adapter fitting available that inserts into the quick connect fitting on the TR6060 than has an male AN -3 or -4 on the other side? I bought one off Ebay but it was designed to connect directly to the slave cylinder. I'm looking to retain the factory hard line / quick connect assembly and go AN hose up to the clutch master cylinder.
​​My LS swap E39 BMW is dropping the 4L80E and getting a TR6060 and I need to figure out the hydraulics.
Thanks in advance!
S.F.
Old Oct 23, 2018 | 09:01 PM
Project GatTagO's Avatar
S.F.
What application is your tr6060 from? Is your slave from the same car?
Andrew
Old Oct 24, 2018 | 04:19 AM
StolenFox's Avatar
S.F.
Andrew
2010 Camaro SS and yes, the slave is from the same car.
Thanks!
S.F.
Old Oct 24, 2018 | 08:26 AM
rickpaw's Avatar
I used this fitting from McLoed. It connects to the slave hard line quick connect fitting, and converts it to AN fitting.
https://www.summitracing.com/parts/mcl-139160
Old Oct 24, 2018 | 08:28 AM
rickpaw's Avatar
Here's a photo of it installed in my TR6060
Old Oct 24, 2018 | 08:46 AM
StolenFox's Avatar
Awesome, thank you for the help!
S.F.
