Overfilled Engine Oil
Old Nov 7, 2018 | 04:13 PM
Highlander18's Avatar
Default Overfilled Engine Oil
Hi team. 2005 LS1 motor. What is the measure in ML between min and max on the dipstick? I have gone over the max line by 1cm.
Any issues with this or will it be ok
Old Nov 7, 2018 | 04:18 PM
Kjduvall's Avatar
1cm is no big deal at all. Alot off road race guys run 6+ qts all the time. Your fine drive it.
Old Nov 7, 2018 | 04:22 PM
dan95gst's Avatar
i used to run my GTO LS1 around 7-7.5 quarts when i was doing a track day. never any issues until all the high RPM ate a stock lifter/cam/engine but that was just due to use/mileage not oil fill level.
Old Nov 7, 2018 | 04:25 PM
Thanks Buddy
HaHa Cheers Dan
Old Nov 7, 2018 | 04:28 PM
Kjduvall's Avatar
1cm is .394 of an inch with engine not running spaced out front to rear/side to side . That ain't like you put in 8 + qts. Your good man.
