1968 Firebird Conversion - Pan, Mounts, and Headers
Old Dec 24, 2018 | 05:13 PM
buckies67's Avatar
Default 1968 Firebird Conversion - Pan, Mounts, and Headers
Christmas came a little early and my Thompson Motorsports 408 arrived a few days ago. I'm dropping this into my 1968 Firebird. It has stock suspension and steering and will be connected to a TKO 600.
I've already purchased a Holley 302-3 oil pan. I'm now trying to settle on the correct motor mount swap plates and headers. I originally planned to use Kooks headers, but then I saw Texas Speed's headers. They're about 50% of the price of the Kooks. https://www.texas-speed.com/p-4273-t...e-headers.aspx. Anyone with experience with Texas Speed headers or the Kooks? Holley has a good option, but those are also a lot more expensive than Texas Speed. Also, I'm looking for advice on which ls conversion motor mounts I should use (with any of the foregoing headers) to get the optimal angle and to get clearance for the headers, pan, and steering/suspension? Dirty Dingo Double D's? Holley's mounts? Other options?
Thanks!
Old Dec 24, 2018 | 05:38 PM
GonHuntin's Avatar
Mixing "systems" is a crap shoot......spend the $$$ for the Holley stuff, it fits and the saved frustration and hassle is more than worth the extra cost..
Old Dec 24, 2018 | 07:33 PM
+1 for Holley swap mounts. If the TSP headers will fit, go for them. Even if a little tweaking is involved. Otherwise, Holley all the way. The extra $$ spent will minimize headaches all around.
Old Dec 25, 2018 | 09:00 AM
968ls1's Avatar
Default Holley
Go with the Holley “system” you won’t regret it. Just helped a friend do a 67 Camaro LS3 and everything fit perfect. Mixing and matching can be a buzz kill when something doesn’t fit or has to be modified.
