CD009 Trans in a Chevelle?
Old Jan 6, 2019 | 12:06 PM
Project GatTagO's Avatar
Originally Posted by gofastwclass
Dual CV or Guibo / Giubo (however it's spelled / pronounced)? Like a new car (G8, CTS-V, 2010 up Camaro, etc.) right?
Having driven both I prefer the T-56 / T-56 Magnum / TR6060 family of transmissions to the TKO series. Plus the double overdrive on the T-56 series is nice. From what I see the TKO looks to be an older design with new applications.
Dual Rzeppa CV, like in my Cougar.
Andrew
Old Jan 6, 2019 | 01:37 PM
wyattroa's Avatar
Thank you for all the information. I think I am going to go the t56 route with the 2.66. Not sure if I need the double overdrive versus the tko600, but I have heard they have issues shifting over 6k rpm. I have a 3.89 rear gear and the tires are 27" tall. The CD009 doesn't see like it would be a good choice for my setup. Thank you again.
Old Jan 6, 2019 | 02:16 PM
gofastwclass's Avatar
Andrew
Yep, that's the one I thought you were talking about!
Old Jan 6, 2019 | 04:30 PM
Robert,
With a 27" tire and 3.89 gears, you're going to be just a hair over 1800rpm @ 75mph (I consider this a good highway speed), and your driveshaft will be spinning at just a hair over 3600RPM. Two suggestions:
1. I highly recommend the dual CV driveshaft from The Driveshaft Shop.
2. Make sure that whatever cam you pick will be happy in that 1700-1800RPM range.
Andrew
Old Jan 6, 2019 | 04:33 PM
Michael Yount's Avatar
Is that a carbon fiber shaft Andrew? What DIA? Those folks are right up the road from me and I've been wanting to try them out....
Old Jan 6, 2019 | 04:34 PM
Yes, CF tube, I believe it is 3.25". Driveshaft shop also offer a lower cost aluminum tube option.
Andrew
Old Jan 6, 2019 | 05:03 PM
Cost not so much of an issue; overall diameter is however due to limitations in the tunnel. Suspect they'll want to do a 3.5" AL. Unless I can talk them into a larger wall thickness 3.0". I'll drive up and have a talk with them. Thx.
Old Jan 6, 2019 | 06:58 PM
FYI, I'm up for adoption if you are looking for a son with fabrication skills to help subsidize his car projects.
Old Jan 6, 2019 | 07:12 PM
Duly noted!
