Bouncing Voltage Gauge
Old Feb 6, 2019 | 06:32 AM
87944turbo's Avatar
Default Bouncing Voltage Gauge
Recently installed a LS1 in my 1987 944 turbo and immediately noticed the voltage gauge bouncing. Never an issue with this gauge in the past. I have done some reading online, but haven't found a ton of info on this issue. With the engine running, I am reading ~14.45 Volts at the battery terminals. Any suggestions other than checking all the grounds?
Old Feb 6, 2019 | 09:49 AM
garys 68's Avatar
If it's not the gauge and only does it with engine running, it's probably a bad rectifier in the alternator.
Old Feb 6, 2019 | 08:15 PM
Pop N Wood's Avatar
Don't measure the voltage at the battery. It will smooth out the ripples. Measure it at the fuse box and see if an external gauge bounces.
Old Feb 27, 2019 | 05:15 PM
87944turbo's Avatar
Thanks for the help guys, I think it was the rectifier. I sent it out to be rebuilt as a 1 wire (figuring the rectifier was shot anyway) and wanting to simplify things. Rebuilt alternator works great, the voltage gauge bounce is gone, shows 14.60V solid at the battery.
Old Feb 28, 2019 | 04:57 PM
Pop N Wood's Avatar
I love a happy ending
Shoot. I should own the patriots.
