1987 Chevette LS1 swap
#203
Got the Chevette back out last weekend and I got the front end tore back apart already. Figured I needed to replace the bushings in the control arms then get an alignment done. I'm also thinking about putting a cam in it soon. I was thinking about a BTR stage 3 or something from Texas Speed.
#205
#208
No pics, but I got all the bushings changed in the front and just waiting to get some time when the weathers decent so I can get an alignment done. I planned to take it in last Friday but it was snowing and raining so that didn't happen. Yesterday it was back up into the mid 50's so I figured I'd work on buffing the paint back to life. Hit it with a clay bar and then a buffer.
Motors coming apart this week for a BTR LS1 Stage 3 cam. I'm going to pull the heads and put some new lifters in it while I'm at it. I'm also going to put a Melling 10295 pump in.
#211
Found some cracks in the flexplate in the ring gear next to all the torque converter mounting holes while the motor was out. Didn't realize this was such a common problem until I did some search on the forum. Picking up a new one tonight then finally start putting this back together.
#212
I spent the past few days working on the interior. I spent most of the time getting the back seat to fit. I also put some heat insulation on the firewall and floor. Made a huge difference on the amount of heat in the car.
The following users liked this post:
G Atsma (05-22-2020)
#215
I got the 4 link brackets welded on my crossmember last night and decided to check and see how straight the rear was before I cut the ends off. The one side was about perfect, but this side was a bit off. I think I'm going to straighten it before I try to narrow it so when I go to weld the ends back on everything lines up.
Thanks for sharing the pics on your fab work. I tend to gravitate towards fabrication stuff and really enjoyed seeing some of your process.
G Atsma (07-11-2020)
#217
Thanks. Yeah, shows how much I like this thread that it got me to post for the first time. I pop in from time to time to see what's going on in LS world. My first stop is usually Conversions & Hybrids because I love the out of the ordinary stuff people are swapping LS's into.
#218
Can I ask what jig you used to narrow the rear end?? Is that the Mittler set-up? I have the Alston but it has the short bar. I'm thinking about getting the longer bar.
#219
#220
The only part that was bought premade was the 4 link kit with the 4 link crossmember. They came from Chris Alston's Chassisworks.
