California Erod Install
You’re really very annoying with all your know it all (KIA) petty bullshit semantics I’m well aware of where the emission related equipment is located and what it does, 37 years a mechanic, 26 of those at 2 dealerships, Just stop please.
Its been a couple days since I have been able to check in and benefit from all your comments thanks a ton,, Tusk427 you gave some great information and your troubles will help me get through the process thanks for posting.
I did want to submit to all the most recent CARB requirements for swapping out a controlled engine for another and how that left me with only 2 engine choices, 1 Rebuild the original 305 leaving the choked out smog in place, well there's no gain for me there so that's out. Choice 2, Purchase the CARB approved EO D-126-30. The limitations in choices are subject to, 2 category's that I can identify, Classification and GVWR. Within the last couple of years CARB has amended there regulations limiting swaps to, 1- if you have a truck as I do then I can only swap into mine a newer truck engine, now here's the kicker. Within the amendment they added language that the doner vehicle " in my case a doner Truck" has to stay within your original vehicle's GVWR my GVWR is 5600. you can look but you wont find a factory emissions controlled truck with an LS engine in it with a GVWR of 5600. So classification " vehicle type" and GVWR weight limitations have excluded every LS engine out there from being candidates leaving me with my second choice to purchase a engine with an approved E.O. that removes the car truck classification and includes approval for vehicle's up to 5700 GVWR.
Tusk427 I would like to get more from you in regard to the troubles you had with the cold air intake, and that it as well needs an executive order I have not came across that, really do the cold air intake has to have an E.O.
You also mentioned a new fuel cap, from what I have read that the fuel filler tube has to be 2006 or later. did you get away with swapping from a vented to a non vented cap?
And the Amber MIL light I know there looking for a mil light I had no clue it had to be amber guess Ill have to verify, luckily my dash is still apart.
Ill post a couple pics in the next posts thanks again to all.
I have completed the install put the truck back together it started right up, a few issues like the oil pump would not prime on its own?? manually primed it no more issues runs great even got the AC completed hoses and mating the fittings to the new compressor was a challenge.
I'm now preparing to go to BAR and hopefully get signed off. I purchased a scan tool to check my readiness and after several drive cycles the 02 Sensor will not ready leaving me with 1 flag. The computer has no codes and the MIL is not illuminated, but verified to be working during the self check at startup. Has anyone had this issue I have put about 400 miles on the truck completed the drive cycle at least 4 times cleared the computer with the tool effectively resetting the sensors to not ready and repeating the drive cycle and even cleared by battery disconnect. efter each drive cycle the pesky 02 sensor is the only one that wont set. if anyone can share some thought it would be appreciated.
Thanks for all everyone's help..
