1970 blazer swap
My blazer will be on road 100% of the time (no off-roading) - it will be a fair weather cruiser/very little interstate driving.
There are such mixed reviews about these trans options:
nv3500 - weak but good gear spacing...etc
nv4500 - strong but bad gear spacing... etc
any suggestions?
However, I would think the creeper 1st gear would get old after a while with NV4500. Do you know what axle gears you have? And what tire size you will run? That might have an impact on your decision, also. I'm guessing 3.73s if they are stock. With reasonable axle gears, either 3.08s, 3.42s or 3.73s, then you could get by without the overdrive trans, and keep the 465 if you like the way it shifts.
BTW, I think your original t-case should be an NP205, not a Dana 20.
Below is my 71 Jimmy, I run a LQ4 and 4L65e, very happy with this setup. It was originally the same as you- 350/SM465/NP205, but the engine had been swapped to a pretty gutless 283 by a previous owner. I like manual transmissions, in general, but I like the auto in this application. Ours is also just a street cruiser. I run an NP208 t-case, 33s, and 4.56 gears.
http://67-72chevytrucks.com/vboard/s...d.php?t=770894
However, I would think the creeper 1st gear would get old after a while with NV4500.Do you know what axle gears you have? And what tire size you will run? That might have an impact on your decision, also. I'm guessing 3.73s if they are stock. With reasonable axle gears, either 3.08s, 3.42s or 3.73s, then you could get by without the overdrive trans, and keep the 465 if you like the way it shifts.
Gears are currently 3.08. I’m thinking tires will be 33x10.5.
Some 69 & 70s came with the Dana 20 tcase - somewhat odd.
Your jimmy looks great - I’m on the 67-72 forum too. I remember reading your thread when you posted it.
