Starter for crate Ls3
Old Apr 15, 2019 | 11:52 AM
ijimmy's Avatar
looks to me like you have the wrong starter bolts , clearly in your fist picture you are into the knurl portion of the bolt , end of threads
Old Apr 15, 2019 | 08:24 PM
Yader20's Avatar
if this were the case though the starter would be loose with the bolts tight and the starter is solid. i checked part numbers and the 2010-2015 camaro are all the same starter. i ordered the bolts that were on gm parts direct website for this starter it seems to me that the part of the starter bottoms out on the inside of the bell housing not allowing it to pull farther up towards the block. Like some others have said i wonder if i need to grind out part of the bell housing to make room for it to pull the rest of the way up
