280z swap, solid axle question
Specific questions/comments:
1) does anyone sell a 4 link for this car?
2) has anyone had luck adapting a 4 link kit?
3) I understand there will be fabrication required, but would like to avoid backhalf/ tube frame
4) does a solid axle require notching of the frame rails to allow for stock or lower ride height?
5) pics of solid axle setups?
6) other considerations?
Thanks!
Chassis works has a lot of options for rear clips.
There are also more durable options if you want to retain the IRS.
Andrew
Hybridz used to be my favorite place on the internet but it isn't what it used to be. There should, however, be some write ups of solid read axle cars. My suggestion would be to find a solid rear swap on there and PM the guy who did it.
I will also add the swaps I can remember involved pretty extensive metal work. Not much room under a 280z.
Thanks
https://forums.hybridz.org/applicati...2d748f178a56e6
I'm not a fan of the r230 swap. Seems like a lot of work, expense and weight compared to what an R200 gives you. The R200 can be made to go, no questions about that. But bench racing being what it is people always think they need more.
Tires are also a huge part of the equation. Stock fenders severely limit tire width, sort of a natural driveline saver. Going solid rear usually means tubbing the rear allowing serious meat.
wolf creek racing
http://www.modern-motorsports.com/da...onversion.html
https://www.silverminemotors.com/240...t-turbo-shafts
