Bleeding slave cylinder
Old Apr 7, 2019 | 10:41 PM
48studebakerbusinesc's Avatar
Default Bleeding slave cylinder
I am swapping LS-3 and TR6060 into my 48 Studebaker ,the motor and trans are out of a 2010 Camaro SS. It seems like i have all the air out of the clutch system ,but takes a couple of pumps to get a pedal ,but then it is hard like a brake pedal, and doesn't move,and clutch still doesn't disengage.I used a Wilwood single
r master cylinderr,and the master is mounted under the floor ,below the slave. Any thoughts?
Old Apr 8, 2019 | 06:26 AM
ijimmy's Avatar
looks like the push rods are at an angle and not straight , and they are short , both issues can cause , mechanical problems for your masters. Also it looks like your slaves are above your masters , that will give you another issue . Ive never seen that done on a hydraulic clutch , brake yes [with a residual valve ]
Old Apr 8, 2019 | 06:40 AM
gofastwclass's Avatar
I agree with ijimmy on all accounts.
Another future issue with the excessive angle is side loading on the master cylinder bore which could wear it out faster than a straighter run.
