Ignition cuts out
Old May 23, 2019 | 06:56 PM
55-408's Avatar
Angry Ignition cuts out
LS engine with a Daytona Smart Spark. It starts and runs fine for about 10 minutes then suddenly and instantly stops, It will not restart unless I pull the alternator plug, then it will restart and run fine, but of course there's no battery charge. The alternator is a Remy CS130D type and It's wired per the Painless harness instructions; 12v keyed ignition on the I terminal and 82 ohm resisted 12v on the L terminal. when running the alternator puts out a constant 13.9 -14.2 vdc and checking, the ac voltage is a constant 0.17 - 0.21 so the diodes should be good. I've tried removing all other accessory and fuel pump connections with no help.
Any ideas or help would be appreciated.
Old May 23, 2019 | 09:51 PM
Welcome to LS1Tech! What engine? What vehicle?
Old May 23, 2019 | 11:00 PM
55-408's Avatar
Default 55
Its a 55 Chevy hardtop just painted Imperial Blue. Engines an L96 iron short block all forged from Texas Speed. 408" LS3 heads, Comp cam and headers into a built 4L60e and a Ford 9"
Old May 24, 2019 | 06:22 PM
Project GatTagO's Avatar
How is the Daytona Smart Spark wired? Where is the alternator put lead go?
Andrew
Old May 24, 2019 | 07:40 PM
55-408's Avatar
Default ignition
The Smart Spark is wired with a Daytona adapter harness connecting to an MSD harness. Pins are straight and the harness checks out OK.
The alternator B terminal is wired from the starter solenoid, piggybacked from the battery +. The alternator l and L terminals are wired from the ignition switch.
Old May 25, 2019 | 07:06 AM
Everything sounds like it is properly wired. The question is, what changes after 10 minutes of running? Obviously the engine warms up. Have you tried starting it without having the 4 pin connector hooked up to the alternator? It should put out a constant 13.8v without anything connected. If it doesn't die after 10 minutes, like before, you have some place to focus your attention.
Andrew
Old May 25, 2019 | 03:46 PM
55-408's Avatar
Default ignition
Thanks Andrew, the engine does start with the 4 pin connector removed, but there is no charge from the alternator. Previously when running and then dies, the engine will start and run with the 4 pin connector removed but as soon as I plug the connector back in, it kills the engine. There's some glitch coming from the alternator I can't figure. While the engine is running the voltage output is steady around 14 volts when it dies. The Daytona Smart Spark is suppose to be good for 19 volts.
Old May 25, 2019 | 04:24 PM
I'd say if the alternator is not putting out 13.8v without the plug, then I am leaning towards a bad alternator.
Andrew
Old May 26, 2019 | 12:08 AM
55-408's Avatar
Default ignition
I thought the alt needs 12 volts on the L terminal or exciter in order to work.
Should the L terminal have 14 volts when when running?
Old May 26, 2019 | 06:08 AM
The L terminal gets switched 12v but it needs to go through the gen light circuit or have a resister added to drop the voltage. If you feed 12v to the L terminal, that will burn up the alternator.
Andrew
Old May 26, 2019 | 11:21 AM
55-408's Avatar
Default ignition
Understood. I am feeding the L terminal with 82 ohm resisted 12v. What I meant was that when the engine is running the alt L term output is 14v.
Does this mean the alt is bad? Its a reman Remy from China. Guess I shouldn't expect much.
Thanks again, Ken
Old May 26, 2019 | 11:39 AM
Thanks again, Ken
Ken,
I have never tested this, but I always ASSumed that the L terminal is strictly an input and you should not get any voltage on it when the engine is running. Also, I am not sure where you got the 82 ohm resister value, but the Holley alternator pigtail (pn 197-400) uses a 560ohm resister. And as you said, you may just have a bad alternator.
Andrew
Old May 26, 2019 | 11:49 AM
55-408's Avatar
Default ignition
The 82 ohm resistor is what Psinless Performance wiring claims to be the "proper" resistor. But I'll check further.
Old Aug 23, 2019 | 01:31 PM
55-408's Avatar
Default finally fixed
The problem was the crank sensor. When the engine would get hot the sensor would short and make the ignition go haywire. I replaced the sensor with a Delco (even if its made in China, its the original GM spec), added another insulation sleeve, changed the thermostat to a 160° and lowered the fan to 160° which an external temp but keeps the water temp about 180°-185°.
