Help solving my light throttle surging issue?
I've put about 300 miles on my LS swapped 1968 Camaro. I'm trying to isolate an issue I've been having with light throttle surging. It only happens at light throttle and will completely go away around 3500 rpms, and higher. I have no problems at idle, but will start to surge around 1300 while driving. Background on the motor: I built the top end of my engine, SBE LS1, with LS2 cam (and front cam conversion), LS6 valley cover, stock 799 heads, LS6 intake and 85MM MAF with a CAI.
The car runs great at WOT and above 3500 or when I'm giving the car moderate-heavy throttle. The motor almost seems as if it is gulping for air. I can't really tell if it's too much or too little, but that's the feeling it gives. I've confirmed that I have 58PSI through the whole rpm range, I checked for vacuum leaks with no luck of finding one, and I just did a TPS and IAC reset last night. Still no dice.
When I first put the car together I didn't realize that I had the old style LS6 valley cover without the integrated PCV valve, so I did have an issue with the engine pulling a large amount of crankcase vacuum. I've since added an inline PCV valve and that solved that issue. I also tried last night what the car would do if the crankcase was vented to atmosphere, and that didn't change the surging either.
I confirmed that the IAC is functioning with my HP tuners program and it moved while I added the counts, although it didn't appear to completely close? I also tried completely unplugging the IAC last night to see if that would change things and it didn't. It also didn't give me any codes which I thought was a little strange.
I'm currently in the middle of doing a LTFT adjustment for the VE Tables, so the MAF is set to fail at 1Hz so it shouldn't have any affect on the tune at this point. I've added roughly 10% to some cells but it had zero change to the surging problem good or bad. At this point I'm leaning towards either a very small vacuum leak or a bad IAC.
Anyone have any thoughts or worked through a similar situation?
Thanks,
Ryan
lean mixtures demand much more KV to bridge the plug gap. Hope you get it corrected !!
While cruising and during the surge, try these one at a time to narrow the problem to airflow, timing, or fuel:
1. Go into Special VCM Controls and lock the IAC in a set position to see if that helps. Don't let the IAC move. Put it at both low and high extremes to see if that effects the surge.
2. Next, go to spark control where it says Spark Control - Absolute. Set it to about your average cruise advance. Then knock out 5 degrees from the base timing, and then try adding 5 degrees to the base timing.
3. Last, go to the AFR control. Try low and high extremes. Usually a very rich AFR will stop the surge.
That should help you find your main focal point.
Here's a link to the picture I'd seen ... Flyin' Miata Intake Baffle
I owe you a beer. :-)
What I want to do is compare the tune that I build using the 01 Z06 tables to the one that is on the car now to see what tables are different and hopefully isolate the issue. Once I determine the cause I'll update this thread for someone in the future. I'm guessing when I was copying the tables, something was conflicting that was causing the rpm's to "hunt".
Let me know how that works out. I do all the conversions for V8 roadsters. I might just start incorporating that from the get go. Which chassis did you start with? Seems to be biggest problem on the NB.
