Throttle position issue
Old Jun 26, 2019 | 09:46 PM
HRDWRK's Avatar
Default Throttle position issue
Hi:
I have this 4.8 out of a 2001 truck on my engine test stand that I build myself. The ECU was worked on by Brendan at LT1 swap, just basic stock reprogramming. I did my wiring harness modification based on LT1 website.
Anyway, the problem I have is the engine revs extremely high, I don't have a tach connected to it but if I want to guess it would be 3000 and higher, at start and it doesn't settle down unless I disconnect the throttle position sensor connector. If I disconnect the TPS, it idles nice but of course if I try to rev engine (cable driven throttle) it revs up but then it tries to die when it idles. I thought the sensor might be bad, I swapped the TPS sensor with my other Vortec engine that I put in my 79 Camaro, no difference. So, any idea where to go from here and how trouble shoot? Could it be the ECU programming? Did I miss anything with my wiring harness modification?
Thanks
Old Jun 28, 2019 | 09:56 PM
HRDWRK's Avatar
I guess nobody has had such a problem?
Old Jun 29, 2019 | 09:49 AM
jeffs55chevy's Avatar
maybe an issue with the idle air control valve sticking?
Old Jun 29, 2019 | 03:38 PM
HRDWRK's Avatar
If it was the control valve issue, why the idle drops when I disconnect the wires? It is confusing.
Old Jun 29, 2019 | 04:08 PM
brandon6.0's Avatar
Seems wierd. Without a scanner to log tps %, your kind of in the blind. A bad tps will cause some crazy issues.
Check tb set screw to see if tb is closing completely.
No vaccum leaks???
