C10 DBW TAC problems
Old Jul 5, 2019 | 02:00 PM
Jrgunn5150's Avatar
Default C10 DBW TAC problems
Using a P59, 2003 Yukon base tune. 6.0 LQ4 engine.
I have 2 different metal backed TAC modules here. Trying to use a 6.5 diesel pedal for bolt in ability to my firewall.
I pulled both TAC's and harnesses myself. Both from 2003 Silverado's. One is a 6 wire I completely botched the repinning of. Truck would start and idle, no throttle response.
So I grabbed another pedal/TAC/TB/TAC harness for trouble shooting. It has throttle response, will start and idle, then loses communication. Found a broken wire on it. Also found out it has 8 wires, instead of 6 like the other one.
So... Which harness is the proper one to use with a 6.5 pedal? Are they interchangeable on the 2003 TAC module? And how exactly is it supposed to be repinned for the 6.5 pedal, because I find conflicting information everywhere.
Old Jul 5, 2019 | 02:45 PM
I would use a pedal like the ones that come with the engine you are using. FAR more compatible.
Old Jul 5, 2019 | 04:45 PM
brandon6.0's Avatar
Yes. like stated above u need a matching pedal and tac module. If they don't match up correctly u will have issues. I've had issues with them not matching the same yr ecu. Just modifie a 2003 dbw pedal and bolt it into the c10. I do it all the time.
OR get u a drive by cable harness, Cable tb, and a stock Silverado throttle cable. Thin u can reuse the original gas pedal etc. Easy peasy!!!
Old Jul 5, 2019 | 07:43 PM
Jrgunn5150's Avatar
Lol.
The answer, I figured out myself, is the 9 wire harness is 03-05.
To use the 9 wire 03-05 harness with a 6.5 diesel pedal,you switch,at the pedal side, pins A and J. Put A where J is,and vise versa.
Hopefully this helps someone in the future.
Old Jul 5, 2019 | 09:28 PM
brandon6.0's Avatar
Good deal!!
Old Jul 1, 2020 | 01:27 AM
xEtherealx's Avatar
Originally Posted by Jrgunn5150
Lol.
I think you mean to swap A and E, not A and J
