Shifter wiring question
Old Jul 20, 2019 | 10:08 AM
Delfygo's Avatar
Default Shifter wiring question
Hi all hope I can explain this correctly. I'm building a Foxbody LS swap drag car with a 5.3 LM7 and 4L60E from a 02 Trans Am.
I just competed install of the shifter witch is also a Fbody shifter from a TA. My wiring harness is a truck harness that uses a side mounted lock out on the transmission, the fbody 4l60e has a shorter shift shaft and the lock out is on the shifter itself. I want to wire just the basic P,R,N,D to help the computer adjust engine rpm accordingly.
Can anyone help with wire to wire color code to complete this. The wiring is close however there are a few colors that don't match.
Shifter lock out
truck harness plug
There are 2 green - truck same color green fbody one light one dark
Truck has a red and fbody has orange
Truck has a black , fbody has black and brown
Truck has yellow no close matches on fbody.
Truck has purple fbody has purple
I'm just looking for the basics as this won't be street driven
Hopefully I made some sense as I'm no wiring guy.. Lol
Thanks for any help will be greatly appreciated
