63 Nova Wagon 5.3 Swap - The Patina Mobile...
The Build....
Engine
2010 5.3 LS Aluminum Block
799 Cylinder heads
Small Howard's cam
DOD Delete
F-body oil pan
CTS-V serpentine setup
Transmission
2006 GTO 4l60e
Rebuilt with upgraded internals
3200 stall Circle D
Suspension and wheels
All CBR components front and rear
DSE Minitubs
Moser 9" with Wavtrac
Weld RT-S wheels
18x9 front, 18x10 rear
265/35/18 front, 295/35/18 rear
Speartech wiring harness
Dakota Digital Gauges
Vintage Air AC
So the patina mobile hit the rack. First order of business was to get it stripped down and ready for install. Before I removed the rear suspension, I welded in the frame stiffeners and the 4-link brackets while keeping the weight on the rear of the car. Also welded in torque boxes and sub frame connectors.
Brackets welded in and stock differential removed..
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-m5cmmr9.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714924d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-m5cmmr9.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-bh9fnag.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714925d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-bh9fnag.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-indijd7.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714926d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-indijd7.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-l6rt7zu.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714927d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-l6rt7zu.jpg)
New CBR sub frame connectors installed
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-pwgq1lh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714928d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-pwgq1lh.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-knzp0pw.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714929d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-knzp0pw.jpg)
In addition, we are doing a mini tub using DSE tubs. Pretty much the finished product, install was same as coupe or sedan, no secrets here...
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-tkvi5id.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714930d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-tkvi5id.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-rmm1xbg.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714931d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-rmm1xbg.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-xolmz9h.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714932d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-xolmz9h.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-sjp0jap.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714933d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-sjp0jap.jpg)
Prepped the firewall to make ready for new CBR front end....
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-zd5sa63.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714934d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-zd5sa63.jpg)
Interesting find.....see if you can make out what it says....hint, has something to do with interior of car...
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-exrriq6.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714935d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-exrriq6.jpg)
All primed and ready to go....
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-cvj7ndw.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714936d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-cvj7ndw.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-jbzweyh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714937d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-jbzweyh.jpg)
A little brake line action....all stainless, -3AN throughout.
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-wgvgxvb.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714938d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-wgvgxvb.jpg)
SO that gets us to here....CBR Supplied Moser spec fabricated 9" rear end, shortened 2" each side with Wilwood 13" 6 piston caliper brakes....295 tires on back. No, the brake line is not running through the shock. It was clocked wrong from Moser. Already re-clocked it....
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-zarbbon.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714939d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-zarbbon.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-rmiiyp8.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714940d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-rmiiyp8.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-vlnrbi1.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714941d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-vlnrbi1.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-2e0hz0l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714942d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-2e0hz0l.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-6pkocux.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714943d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-6pkocux.jpg)
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-vbhkvj4.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714944d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-vbhkvj4.jpg)
And sittin' on the ground. Just preliminary settings right now. Will set ride height, wheel base and center up once I get all the weight on the car.
![63 Nova Wagon 5.3 Swap - The Patina Mobile...-xcjrm10.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714945d1683231826t-63-nova-wagon-5-3-swap-patina-mobile-xcjrm10.jpg)
That gets us to today, feel free to ask any questions....
T,
Engine
799 Cylinder heads
Small Howard's cam
DOD Delete
F-body oil pan
Transmission
2006 GTO 4l60e
3200 stall Circle D
DSE Minitubs
Weld RT-S wheels
Vintage Air AC
T,
The Build....
Engine
799 Cylinder heads
Small Howard's cam
DOD Delete
F-body oil pan
Transmission
2006 GTO 4l60e
3200 stall Circle D
DSE Minitubs
Weld RT-S wheels
Vintage Air AC
![](https://i.imgur.com/M5cmMR9.jpg)
![](https://i.imgur.com/BH9fNAG.jpg)
![](https://i.imgur.com/INDIjd7.jpg)
![](https://i.imgur.com/L6rt7ZU.jpg)
![](https://i.imgur.com/PWgQ1Lh.jpg)
![](https://i.imgur.com/KnzP0PW.jpg)
![](https://i.imgur.com/TkVi5iD.jpg)
![](https://i.imgur.com/RMM1Xbg.jpg)
![](https://i.imgur.com/xoLMz9H.jpg)
![](https://i.imgur.com/SjP0jaP.jpg)
![](https://i.imgur.com/zD5sa63.jpg)
![](https://i.imgur.com/exrrIQ6.jpg)
![](https://i.imgur.com/cvJ7ndW.jpg)
![](https://i.imgur.com/jBZWEyH.jpg)
![](https://i.imgur.com/WgvGxvB.jpg)
![](https://i.imgur.com/ZaRBBoN.jpg)
![](https://i.imgur.com/rmIIYP8.jpg)
![](https://i.imgur.com/vlnRBI1.jpg)
![](https://i.imgur.com/2e0hZ0l.jpg)
![](https://i.imgur.com/6pKOcUx.jpg)
![](https://i.imgur.com/VBHKvJ4.jpg)
![](https://i.imgur.com/XCjrm10.jpg)
T,
Engine
799 Cylinder heads
Small Howard's cam
DOD Delete
F-body oil pan
Transmission
2006 GTO 4l60e
3200 stall Circle D
DSE Minitubs
Weld RT-S wheels
Vintage Air AC
T,
