LSA swap Gbody
I know the low mount AC wont fit unless i cut a notch in the frame and i am considering doing that.
Link https://www.jegs.com/i/Chevrolet-Per...43525/10002/-1
This, and the looooong G-body swap thread will cover many questions https://ls1tech.com/forums/conversio...est-block.html
The pretty-far-forward stock frame-side mounts are in a dumb location if you're trying to run the low mount compressor. Go for something that bolts to the frame further back.
The area of the pass side frame behind the control arms is a spot some have put a pie cut in the top & some slits down the inside, beat in, & rewelded for extra header clearance in a normally tight spot.
