Cam Position Sensor Help On GTO LS Swap
I've got a 2007 6.0 engine. I'm trying to run a 2001 (411) PCM. My engine has the CMP sensor in the timing cover. I've had the correct 24X reluctor ring pressed onto the crank, and I'm using the EARLY CKP sensor (from a 2001 5.3L Silverado). I have the correct 1X cam gear. This was verified, and double, and triple checked.
Here are the questions;
1. I've heard that I have to swap/switch wire positions when using an EARLY wiring harness & computer with the timing cover mounted CMP sensor. Which wires get swapped to where? I assume I can just re-pin them at the PCM to correct this.
2. I've heard that the EARLY CMP sensors are 12V+, and that the LATE 2007 & later CMP sensor are 5V+... I have the LATE sensor as it came with the '07 engine. How do I visually identify that I have the early, or late sensor? If I have the LATE sensor, can it work with the 2001 411 PCM? If not, what vehicle can I order the correct CMP sensor for/from???????
"Gen IV engines mount the CMP sensor in the front timing cover and get a signal from the face of the camshaft timing sprocket. Early Gen IV engines are equipped with a 24x crankshaft reluctor and 1x camshaft reluctor. These engines use the same CMP sensor and timing cover as the later engines equipped with a 58x crankshaft reluctor and 4x camshaft reluctor. The CMP sensor output (1x or 4x)
is determined by the signal surface area of the camshaft timing sprocket."
Courtesy of; https://www.lsenginediy.com/cranksha...signals-guide/
So, does this mean that the entire 12V+ or 5V+. I hope my 2007 CMP sensor works with my 2001 411 PCM.
I also found this;
On cam sensor, you have 3 wires in line. Swap 1 and 3 over.
I will go back to the PCM, and simply swap the wires for pin 1 & 3 in the CMP connector, but do it at the PCM pins.
If anyone sees any issues with the way I'm going about this-please let me know! I'd like to have just ONE new engine start up go as planned.. You know.. The engine actually starts..
B-Low reference (ground)
C-Signal output
when you look at the CAM sensor connector read left to right when the latch is on top
In other words the first two wires =5/12 volts w/ key on. (cam sensor CONNECTOR UNPLUGGED)
a to battery negative = 5/12 volts
b to battery positive = 5/12 volts
a to b = 5/12 volts
If you are uncertain and do not want to probe wires SEE LT1SWAP.COM FOR PIN OUTS AT ECM CONNECTOR and check continuity from ecm connector to cam position sensor connector.
be certain key is off, battery disconnected and ecm and cam sensors disconnected when conducting test
I will still need to check and see if the cover I have installed (and painted!!!!) is a VVT, or NON-VVT cover.. Here's hoping my luck actually holds out for once..
See my next post on fuel injector adapters...
