Tbss on L33
Old Aug 5, 2019 | 08:21 AM
EZA's Avatar
EZA
Default Tbss on L33
I have a 2005 L33 with a Z06 cam and was t thinking of swapping the stock intake for a tbss intake. Researched it and it seems I even if I use the tbss throttle body I will need a tb link that cost about $250 even though both throttle bodies are dbw? Link and tbss with tb $400 plus some other incidentals, don't know if its worth it for a small gain in hp?
Old Aug 5, 2019 | 09:13 AM
JoeNova's Avatar
Restricted User
They are both DBW, but completely different.
I would go ahead and put the intake on and get a cheap adapter to use your stock throttle body until you can find an affordable option.
Old Aug 5, 2019 | 11:18 PM
EZA's Avatar
EZA
After doing some research it looks like I wouldn't gain more than about 10 hp on a mild 5.3 build like mine. I think the money would be better spent on good limited slip unit. Maybe a manifold swap later...thanks for your input.
Old Aug 8, 2019 | 08:30 AM
Kawabuggy's Avatar
Yes there are many dyno results showing that the net gain for swapping over to the NBSS/TBSS intake manifold is not worth what it will cost you to swap over to it. I think for highly modified engines, everyone is going the FAST route. If I were going to invest in an intake swap, it would be ONLY the FAST, or the Dorman intake that has now copyrighted the early FAST intakes.
Old Aug 8, 2019 | 08:51 AM
JoeNova's Avatar
Restricted User
How much do you think it costs to swap over? Even if it costs half of a FAST intake for the complete swap, it gains more than half of the overall power/torque.
Old Aug 8, 2019 | 11:13 AM
brandon6.0's Avatar
Its worth the swap. Will pick up more power with later engine mods as well!
