Injector relay trigger ?
Old Aug 10, 2019 | 08:41 AM
Mikes64's Avatar
Default Injector relay trigger ?
“03” 6.0 I’ve made a smaller fuse/relay panel for fans and injectors/coils,. I also am using a AAW classic update body harness. Did the ECU harness according to LT1 swap. Working on integrating the two together. Question is can I use a 12v ignition source that was originally designed for a distributor type ignition? Thinking all I need is a ignition source to trigger the relay.
Old Aug 10, 2019 | 09:39 AM
If you need a key-on/start 12V source, that will work.
Old Aug 10, 2019 | 08:30 PM
Mikes64's Avatar
Thanks G
Old Aug 16, 2019 | 04:19 PM
stevieturbo's Avatar
As G says, as long as it remains live at all times when the key is on...it'll be fine. Some 12v supplies may drop out during cranking though, so check.
Old Aug 17, 2019 | 01:57 PM
tfi racing's Avatar
Just make sure it is not a resistor wire (used for point type systems) and actually is 12V during crank and run positions.
Old Aug 18, 2019 | 08:35 AM
Mikes64's Avatar
I’m using the American Autowire Classic update harness, 12v ignition feed with no fuse link. I could change this later as I’m using a temp. Fuse panel. Will the loop to the far right work to power left and right banks?
