maf reads max engine idle high
Old Aug 12, 2019 | 07:52 PM
Autobahn's Avatar
Default maf reads max engine idle high
I have a LS2/4L65E out of 06 GTO it has been converted to throttle by cable with a LS1 ECM ,the MAF reads very high and the idle is a 1K,my tuner cant get it idle down , it has a Edlebrock throttle body
Old Aug 12, 2019 | 08:22 PM
Throttle by cable? Or wire? You can adjust a cable. Wire is ECM controlled. Cable controlled by your foot.
Old Aug 12, 2019 | 08:59 PM
Michael Yount's Avatar
Got a feeling cable idle is ecu controlled as well via some sort of idle air control valve.
Old Aug 12, 2019 | 09:36 PM
Yep, forgot about the IAC. It could be hanging up due to dirt, etc.
Old Aug 12, 2019 | 10:28 PM
If these have a throttle stop, should check to be sure that it’s not set too far open.
