Ramcharger fans to ECM/conversion harness
I have Ramcharger dual fans with the original wiring harness which is setup with a manual low-off-high switch. Fans run together in low and high. I would like to run the fans to be controlled through the ECM. The psi conversion harness i'm running has the provisions for fan 1 and fan 2. Can anyone chime in and provide some insight to properly modify the harness so the ECM can support the fans?
Here's how the original harness is steup:
Here's what I was thinking:
