Auto or 5spd
right now car is 5spd out of a Nissan 300zx. They have plenty of 700hp builds on them stock. The rear end will either be 3.69s or 3.45s? Still debating as the 3.69s go in much easier but was told the 3.45s will make the car much more usable.
i don’t do much at the track, maybe that will change when car is done but right now I’m expecting to do weekend driving and around town driving on it mainly. I do plan to be cruising on highway a lot and doing 40+ mph rolls
local builder that very well known on a ton of high hp car will build me a t400 with a brake on it for 2k. Should I go that route? I have 1 experience with a auto trans and it was a t400 built manual valve body on a 383 procharged motor. The thing was sick and shifted instant. Was pretty insane to feel the torque etc always there.
trans is following: RS5R30A
1st = 3.21
2nd = 1.92
3rd = 1.30
4th = 1.00
5th = .75
i have 3 option for the diff
3.69
3.45
3.13
Car isn't tuned yet so never did any driving on it. Will having a 3.13 gear slow it down a lot?
At 6500 in 4th you're at 135 mph with the 3.69's. I'd think 800 rwhp has the potential to trap significantly higher than that.
The 3.45's will get you to 144.
Top end in 5th at 6500 with 3.69's - 180.
Top end in 5th at 6500 with 3.45's - 193.
At 70 mph with 3.69's - 2500 rpm
At 70 mph with 3.45's - 2400 rpm
I was thinking of the 6 spds -- they have shorter 1st, 2nd, 3rd gears than this one.
Based on all this - if 800 rwhp is real, I'd go 3.45's.
I didn't run the 3.13's....but can if you like. Just give me an rpm.....
im using a calculator online and it says with 3.15s on my size tire at 75mph I would be about 3060 rpm. What is the final drive for th400 ? 1.00?
cruising at 75 is about 3060 rpm. Doesn’t seem to bad considering alternative of clutch buying and breaking 5spd trans. Car I would hope is much faster on the th400 manual valve body.
never driven on something with such a long gear. Wonder if that’s going to stress everything. I’ll have to do some googling.
rpm limit, idk. It’s got arp hardware all around motor, .030 over pistons with factory resized rods gen 3. For bottom end. Has cam, btr hardened push rods, btr dual titanium valve springs, btr steel retainers and valve seats.
seems like I have to start just driving speed limit on highway to keep rpm down though. I’ll lookup what 150 trap is in 1/4 mile and I prob won’t run that quick albeit. Highway run from 40-150 should be enough too.
yeah the car is 3300lbs , says 142 is a 9.5 in 1/4. I don’t think I’ll ever run that lol. I’ll have the power and setup to but doubt I’ll get the car to track standards and tires and my driving skill
i don’t think I could get bigger tire. So would have to just work on the gearing. This ain’t my car in picture but I’m copying his tire/wheel setup
