V6 to lq4 wiring help
Old Sep 7, 2019 | 09:59 PM
6.OTOGO's Avatar
Default V6 to lq4 wiring help
I'm new to the site and ls engines in general. Was wondering if anyone has swapped a 2001 Silverado 6.0l into a 2000 Camaro v6. I've got the motor and trans in the car just need to make my 6.0l harness and pcm work with the car. Anyone have spinouts or done this swap that can start me off in the right direction. Im not a nube. Im a Chrysler tech. And I dont want to buy a ls1 harness. I got the pcm and harness with my motor. Lq4 and th400 setup
Old Sep 8, 2019 | 10:07 PM
EFIHARNESS's Avatar
Lt1swap has all the info needed to make this happen.
Old Sep 9, 2019 | 03:52 PM
6.OTOGO's Avatar
Thanks for the link I've seen this site before. But cant find pcm pinout for the v6 I want to wire everything so the bcm and pcm communicate
Old Sep 9, 2019 | 08:39 PM
LS BRAVADA's Avatar
You wouldn't want the PCM pin outs for the V6 because you will be using the donor PCM
You would want the wiring schematic for the vehicle your swapping the engine into.
Old Sep 9, 2019 | 08:55 PM
6.OTOGO's Avatar
If I had the stock pcm pin out I could eliminate the wires I dont need. Keep the one that go to the bcm and pin them into the new harness and not have to lengthen wires or even mess with bck part of the harness. Just a thought might be easier said than done.
