Please help! LS2 swap first start-- let the Gremlins begin
Just got everything squared away and finally started my ls2/ 64 Cutlass swap... We have some issues.
Engine too to bottom, pcm, tcm, trans are all from the same donor vehicle -- 2006 TBSS.
Pedal was snagged second hand from supposedly a 2006 tbss
The issue:
Zero movement in the throttle body from the pedal.
What I've come to this far:
- The throttle body moves a tad bit when I go from key off to key on
- I tested continuity of the wires from the pedal to throttle body and there doesn't seem to be a short or break anywhere
- With key on or run, the yellow wire at the throttle body ( TAC motor control 1) is not getting power per a test light
- C2-60 and C2-63 are both pinned correctly in the E40 pcm
- I got the following codes
- p0122- Throttle/Pedal Position Sensor/Switch A Circuit Low Input
- p0123- Throttle/Pedal Position Sensor/Switch A Circuit High Input
- B2AAA- Body
- p0223- Throttle/Pedal Position Sensor/Switch B Circuit High Input
- p2127- Throttle/Pedal Position Sensor/Switch E Circuit low Input
help.me!!!!!!!!!
- I attached 12v jumper from BAT to the hot terminals on the TB and I get full movement
- With the key on, I tested voltage to the wires at the throttle body connector. Here's my results:
- Purple 4.10-4.80v
- Light blue 5.04v
- Green 6.9v
- Brown 12.5v
- Yellow 12.5v
- Black w/ white 5.8v
I don't know what to make of these numbers but if someone can help me decipher if this is correct readings, it's be much appreciated!
There are 2 parts here, the motor wring, and the throttle position sensor.
The throttle position sensor is a part of opposing potentiometers. So, variable resistors, with one end hooked to ground (Low reference), and one end hooked to 5 volts (5 volt reference). The two signals out will be opposites, and will be between 0 and 5 volts, but never quite all way to one end or the other. SO all of these voltage readings look incorrect. But, also, you won't get any usable reading on the two signal wires, if the harness isn't plugged into the TB.
The other two wires are your two motor leads. This thread details it pretty well
https://ls1tech.com/forums/conversio...r-testing.html
Are you in a position that you can read if there are any fault codes? I don't know the particulars on the TB control, but its not uncommon to disable voltage outputs if a fault is detected.
LOL, at it happens, If you live in Oxford as it says, I live there too. I have some leftover parts from building a 2007 TBSS motor. I have the throttle body on the bench, if you needed to try a spare.
Yes I have a handful of codes ( see #5 in original post). I also pulled some throttle readings from my freeze frame data when codes we're set.
Relative Throttle Position
FREEZE
FRAME 86.67 %
WWW Absolute Throttle Position B
FREEZE
FRAME 100 %
Accelerator Pedal Position D
FREEZE
FRAME 19.61 %
Accelerator Pedal Position E
FREEZE
FRAME 98.43%
Since the codes seem to be APP related, I did some testing on that today. Again, I don't fully understand if these are good results or not but here's what I've done...
1. Tested PCM grounds doing a voltage drop test
- Both grounds tested 1.7v
Sensors 1&2
- Sensor 1 was 3.48ohm at rest and was a smooth sweep to .608ohm at WOT
- Sensor 2 was .926ohm at rest and smooth to 3.62ohm at WOT
- Both sensors were at 5.04v
- Sensor 2 reads good at 11.56v
- Sensor 1....I could not get it to read steady. It would start around 50V then climb up to 145V. I tried retesting this one several times since there's no way 145V are running through anything on this car, but I got the same results each time 🤯
I tested from the ground wire at the block to the ground pin in C2 and then also did from ground on block to the ECM case and get .2ohms for both.
This shows that the ECM ground is good, correct? Earth ground is 0.0, just making sure that's what I'm looking for here.
ALSO, using Torque App Pro I can watch Absolute Throttle position B, and accelerator pedal positions D, E &F, Throttle position and APP. These are all in percentages, so not sure how these translate to voltage readings.
D and E increase as the pedal does.
Absolute B, TPS, and throttle stay the same.
APP and F never give a reading.
The first image is pedal at rest, second is pedal WOT
At rest
WOT
They've sent me a loooong list of additional tests to perform on the app and tps which I'll try to get to this week and I'll update the thread with my findings.
I have a LS2 swapped into a gen 2 camaro. I sort of inheritted the swap part way so there are some challenges. When I started it was always going into limp mode if you held wide open any length of time. That turned out to be someone had the wrong throttle body. They had the gold one that is less expensive and good for about everything else. Swapped back to the correct silver one and problem solved. Fixed other issues and drove it another 6 months and all seemed to be good so the car went to paint.
A year later, car comes out of paint and all is well drive it home and probably have 20 miles on it checking everything out and all of sudden back to limp mode, rough idle, throwing P0123 & P0223 codes. Reset the codes and it comes back.
So where do I start.... is this likely on the TB side or the Pedal side?
Any help appreciated.
