Is into a 91 Toyota pickup
As the title states, I have started this swap project.
Plan calls for an aluminum 4.8 build with a turbo added, 4l80e, Ford 8.8 for a drivetrain and as stock of an appearance as possible.
If anyone has any photos from a similar build or info I would love to hear it.
Thanks. #spicytaco
Still removing the old motor
10lbs in 5lb bag
Thanks. #spicytaco
10lbs in 5lb bag
I'm doing this same swap right now, as we speak. 94 yota Standard cab Rwd 22re 5 speed.
I tackled the suspension, brakes, wheels and tires first. The motor is a forged 370, 7875 .96 a/r billet turbo, T-56 magnum, Ford 8.8 rear.. I compiled pretty much every part for the swap w/ exception of the trans because I need the measurement of the shifter location to order the the correct transmission.
Hit me up if you have any questions. i might have some for you as well.
in the middle of swapping into a 95 single cab yota 2wd . What are the non turbo guys doing for manifolds? I have zero room . Looked into 99 style corvette manifolds but they still aren’t close enough to the block. Any help would be great!
