New Holley Dash
Old Sep 27, 2019 | 03:12 PM
LSX Power Tuning's Avatar
Default New Holley Dash
HOLLEY EFI 6.86" PRO DASH
Touch Screen Digital Dashboard Featuring a High Resolution 6.86" Screen
Holley's new 6.86" Pro Dash delivers over 200 monitoring channels of reliable real-time data in a more compact, full HD package suitable for nearly any motorsports application. Be assured that the Holley EFI 6.86" Pro Dash will deliver the vitals you need! The 6.86" Pro Dash is completely customizable for use in a variety of motorsports applications. It features a 6.86" 1280x480 resolution low glare, high brightness, high contrast, full color capacitive touch screen for easy viewing even in sun, plug and play connection to all Holley EFI systems as well as a weather resistant aluminum housing featuring flexible mounting options. Monitor the power of your Holley EFI system at a glance! Holley EFI 6.86" Pro Dash includes everything needed for installation! The Holley EFI 6.86" Pro Dash also features a plethora of Input and Outputs for expanded functionality of your Holley EFI installation. The included 34pin connector has 13 multi-configurable inputs for most Holley EFI sensors, such as pressure and temperature. Not using Holley EFI sensors? We still have you covered, these inputs are configurable, allowing you to utilize different sensor scaling calibrations! The Pro Dash also features two dedicated speed inputs, for RPM, Driveshaft speed, or any other Hall effect speed input. Need more outputs? The Pro Dash contains 4 ground switched outputs, that can be utilized with the switch panel feature to quickly turn on any of your auxiliary accessories, such as a master nitrous switch, or an electric water pump. We have also integrated a 10-LED Programmable shiftlight into the bezel of the dash, and added 4 optional LED's that can be programmed for virtually anything, such as fuel pressure or oil pressure warning indicators, or a target boost indicator, the options are almost endless.
Features:
  • Plug-and-play Display support for Dominator, HP, Terminator X & Sniper EFI
  • Integrated a 10-LED Programmable shiftlight w/ 4-LED warning indicators for other sensor inputs.
  • Capable of monitoring up to 238 real-time values such as RPM/TPS/Boost
  • 10 default background skins pre-loaded with unlimited options for importing custom layouts
  • Quickly swipe between multiple active screens (tune, warm-up, race, drive, etc.)
  • Virtual switch panel eliminates the need for external toggle switches
  • Manual or auto-brightness features for easy viewing day or night
  • Built-in GPS with odometer function (Antenna included)
  • On-screen datalog playback features allows you to review vital run information
  • Expandable storage via USB
  • No stylus required, capacitive touch, just like your smart phone.
  • User definable channel alarms and warnings
  • 4x 10-32 mounting holes for surface or flush mounting, with high quality hardware included!
  • Includes everything needed for installation!
  • USB Keyboard and Mouse functionality makes it quick and easy to setup new layouts
  • Includes 34 Pin Wiring Harness contains Power, Ground and CANbus connections
  • Input and output functionality for 13 multi-configurable inputs, and 4 ground switched outputs.
  • User defined alarms for any input
  • Upgradable with future software enhancements
  • Viewing area is 6.86" on the diagonal
  • Dash weight - 1.2 Lbs
  • Real-time ECU tuning - HP/Dominator ECUs only
Its a great add on to a terminator if you dont have gauges.
Old Sep 27, 2019 | 09:01 PM
NICE!! Another panel for speedo, tach and fuel gauge and you're set!
OOPPSS EDIT- Tach and speed spoken for; fuel gauge still needed. Or is it?
Old Sep 27, 2019 | 09:09 PM
LLLosingit's Avatar
Not sure what you're saying here, It's a configurable screen you can set it up any way you want as far as gauges/style/size/color/readout and so on. Think of it as a blank canvas and you control what goes on it and what it monitors.
Old Sep 27, 2019 | 09:13 PM
LLLosingit's Avatar
Looks to me like it's identical the 12.3" pro dash except for size, I bought mine a while back but it's still in the box. Edit: Damn I better get to it, I just looked at my purchase date and it was 12-20 of last year. The warranty will be up and I haven't even plugged it in.
Old Sep 27, 2019 | 09:16 PM
Thank you! I didn't read all the info above closely enough. Then I guess it's a full-on instrument cluster! Even nicer!
Old Sep 27, 2019 | 09:27 PM
LLLosingit's Avatar
It actually so much more, Basically you can replace all gauges and dash mounted switches including turn signal lever and all. It has a programable virtual switch panel and you can set up several different screens and simply swipe left or right to bring them up. You can wire the whole car around this and not need anything else on the dash, You can also tune from it and log/playback. The one thing on my wish list would be video input for recording and playback or even to run a back up camera.
Old Sep 27, 2019 | 09:38 PM
Whoa. That. Is, A. Mindblower! Give it time. Your wish list does not sound to far out of bounds for something like this.
Any idea what the cost on this is? Not cheap would be a slam dunk, I bet.
Old Sep 27, 2019 | 10:17 PM
LLLosingit's Avatar
$999 for the 6.3 and $1799 for the 12.3 You can get them a little cheaper if you go through the right dealer.
Old Sep 27, 2019 | 11:11 PM
This, coupled with the Terminator line of OS's, would be pretty comprehensive and keep all the electrical integrated to a common system rather than patching things together piecemeal.
Well done, Holley!
