LS1 5.7 w/ NV3500 in a 1963 c10 help
I know the nv3500 isn't the strongest trans to mate to a 5.7 ls1 but its all I have for now. My question is, what flywheel/clutch/throw out bearing/master cylinder do you run to make this combo work? Any other additional information you may know that'll help me with this swap would be appreciated. Thank you!
Correct- it is internal
LUK 04205 - clutch kit
sachs NFW 1050 - flywheel
LUK LMC357 - master cylinder jeep 4.0
ICT 551393 - flywheel bolts
ARP 134-2201 - pressure plate bolts
LUK LSC326 - clutch slave cylinder
Russell 694870 - clutch hose wrangletrTJ
STANDARD MOTOR PRODUCTS LS205T - reverse switch 58 mm
STANDARD MOTOR PRODUCTS S712 - reverse switch conector
should be the same for LS1
