Reverse light switch - TR6060/LS3 swap
Old Nov 9, 2019 | 07:54 AM
ScottEwine's Avatar
Default Reverse light switch - TR6060/LS3 swap
Good Morning All,
I am going over the wiring for my '73 Corvette LS3/TR6060 swap and want to confirm the wiring for the reverse light switch. I can just wire that into the existing pink/green wire circuit correct? The switch/plug on the passenger side of the TR6060 is open when not in reverse and closed when in reverse? Also, the ECM does not need the signal from the reverse switch, correct?
Let me know if I have this wrong.
Thanks,
Scott
Old Nov 9, 2019 | 08:43 AM
007FJ's Avatar
Correct for my f-body anyways
Old Nov 9, 2019 | 08:46 AM
007FJ's Avatar
Colors are different for mine but that’s all there is too it
Old Nov 11, 2019 | 07:18 AM
67 goat's Avatar
On my 67 GTO with T56 magnum (same as TR6060), I just wired the connector to my factory reverse light wiring (2-wire) and it works as it should. PCM shouldn't care about reverse. So, all your assumptions sound correct to me!
