l96 in 07 tahoe
Old Apr 2, 2019 | 07:02 AM
sbf2's Avatar
Default l96 in 07 tahoe
hi guys my 07 Tahoe engine took a crap and wanted to replace it with a l96 and if it has dod,vvt I want to delete it as well.
first:does the l96 has flex fuel
second:could I use the factory Tahoe ecm after tunning to run the l96
third:would I have to change flywheel to use my 4l60e
fourth:would my all my sensor plugs plug into the l96 engine or would I have to use the 5.3 sensors
Old Apr 2, 2019 | 10:37 AM
01FormulaTA's Avatar
1. Yes, the L96 has Flex Fuel Injectors (50lb), also it does not have DOD but it does have VVT
2. Yes, you can use the factory Tahoe ECM, you will just need to get a tune
3. Yes, you will need to swap over the flex plate from your 5.3 engine to the L96 to use the 4l60e
4. Yes, all the connections from your existing harness will plug into the L96
Old Apr 2, 2019 | 10:52 AM
sbf2's Avatar
thanks alot
Old Apr 2, 2019 | 11:02 AM
sbf2's Avatar
I know I need lifters,head gaskets,cam is there anything else I would need to delete the vvt
Old Apr 2, 2019 | 01:51 PM
VVT is the easier of the two to delete. Cam, sprocket, front cover, sensor. VVT-only engines use all normal lifters.
Old Apr 2, 2019 | 02:31 PM
sbf2's Avatar
Would I still need to remove the heads to replace the cam
Old Apr 2, 2019 | 03:13 PM
Not really. Pull the valve covers, remove the rocker arms and pushrods. Once you have the front stripped down and timing set off, turn the cam a few times to get the lifters "stuck" in the lifter trays in the "up" position. Pull the cam, put in the new one and replace all the parts just removed. Very easy compared to the old SBC.
Old Apr 2, 2019 | 07:57 PM
ijimmy's Avatar
While doing this either have the engine upside down , pan up ,,,,or put 5/16s dowels in the holes by the cam sprocket , rarely a lifter will drop , as the lifter trays wear ,,, usaly on high mileage engines , just a safety precaution , l96 is a hell of an engine
Old Apr 3, 2019 | 06:44 AM
sbf2's Avatar
engine will have 50-80k miles
Old Apr 3, 2019 | 02:58 PM
Barely broken in....
Old Apr 5, 2019 | 07:15 PM
Motown 454's Avatar
I used clean 1/4" brake line
Old Aug 21, 2019 | 06:45 AM
sbf2's Avatar
ok guys i got a 2016 l96 engine but ran into a problem.the 5.3 has a sensor in the rear valley cover beside the oil pressure sensor.the l96 does not whats my next step
Old Aug 21, 2019 | 10:47 AM
It might be the cam sensor if the 5.3 was Gen III.
Old Aug 21, 2019 | 10:54 AM
sbf2's Avatar
the cam sensor is in the front,the tuner just told me it was the afm/dod crap and not to worry about it
Old Aug 21, 2019 | 10:57 AM
Ah! So the 5.3 was GenIV. Yeah I forgot the DOD crap had a connection on the rear of the valley cover.
Old Aug 21, 2019 | 11:01 AM
sbf2's Avatar
yea i actually got a motor with 14k
Old Aug 21, 2019 | 11:03 AM
NICE! Barely broken in!
Old Aug 21, 2019 | 08:43 PM
sbf2's Avatar
Got the engine in the truck tonight but another issue.the map sensor on the l96 doesn't plug into my harness and the map sensor off the 5.3 don't exactly fit in the intake but I think I can modify it to work but would this effect anything
Old Aug 23, 2019 | 06:14 PM
sbf2's Avatar
Got the map sensor figured out my next problem is cam sensor this motor has the cam phaser cover on it and doesn't fit my connector.could I just put the cam sensor harness off the 5.3 and run it.the vvt is turned off in the ecm
Old Aug 23, 2019 | 06:42 PM
You will need to convert the cam drive and front cover over to non-VVT parts to use the non-VVT camsensor plug.
