2015 LS3 schematics needed
1: ALDL schematic. It has changed from the Gen 3 stuff I'm used to. I did a Connect and cruise install and there were data lines in it I hadn't dealt with before.
2: X1 pin 18: serial data wake up. Does it get 12V+ from ignition
3: I can't find an output for a speedometer in my pinouts.
4: X1 27,28. I think these will go to the ALDL.
Anyone know of a source where I can print schematics from. The source I had closed.
thanks guys!
X1 18 not used in your case
X1 27-28 (twisted pair) would go to TCM but in your case now go to the ALDL with a resister (I believe 120ohm) this is high speed LAN
gen 4 now get speedometer from wheel speed sensor or GPS
https://www.ls2.com/boggs/dtcs/Scan_...LAN_Device.pdf
I find it interesting that the E67 PCM has circuit 818 for Speedo but the E38 doesn't. Just something I've discovered. Thanks for the help guys!
i believe you will need one at the ALDL also.
it doesn't seem you have any other modules so I'm not 100%
