Mechanical speedometer help
Old Feb 16, 2020 | 06:13 PM
Lightn95's Avatar
Default Mechanical speedometer help
I'm doing a 5.3/4L60E swap in a '53 Cadillac. The Cadillac has a mechanical speedometer. Does anyone know how, or has made, a mechanical speedometer work without breaking the bank?
Old Feb 16, 2020 | 06:33 PM
HILROD's Avatar
I think you can get an early tailshaft housing and convert it to cable. I did it years ago pressed a gear onto the output shaft. Also there is a thing CABLE X i believe it's called to drive a cable with vss input. The last few cars I've swapped I sent the speedo to be changed to electric.
Old Feb 16, 2020 | 08:08 PM
hotrod51's Avatar
Dakota Digital makes a cable driver 329.00.
Old Feb 16, 2020 | 08:13 PM
Michael Yount's Avatar
I divorced speedo from driveline completely. Speed Classic box uses a gps signal to drive a cable which goes to speedo. Calibrate it using gps on phone. No more worrying about driveline/tire size changes impacting speedo accuracy.
Old Feb 16, 2020 | 11:10 PM
Lightn95's Avatar
do you have a link to that or know where to get it? I looked up "speed classic box" but I couldn't find anything.
Old Feb 17, 2020 | 01:17 AM
CattleAc's Avatar
Dakota Digital ECD-100
Old Feb 17, 2020 | 06:21 AM
https://www.classicautoinnovations.com/classic
