Wiring harness identification
Old Feb 29, 2020 | 07:55 AM
fastlt1's Avatar
Default Wiring harness identification
1999 Camaro z28 6spd engine wiring harness. Got a plug I need help with. Its bundled with the thick purple wire going to starter. 2 prong. I'm thinking ac. I ran the wires back to pin 70. Every diagram says not used.
Old Feb 29, 2020 | 12:55 PM
SE-R Spec's Avatar
Pin 70 on blue connector in the truck harness is low oil level switch (brown)
pin 70 on red connector is not used. Hope this helps you out
Derek
Old Feb 29, 2020 | 03:56 PM
fastlt1's Avatar
Its diffinetly 70 on the red
